what's wrong with my turbo timer?
03MSPRO
05 Nissan Frontier CC 6 spd
I have a HKS TT set to TM 1.00 (manual timer of 1 minute). Half the times, it does not work. When It remove the key from the ignition, the car stalls and dies, why? What's going on? I hate headaches!!!
Check the e-brake wire.
recheck ur wires. sometimes if u jiggle the harness the wires move and make the timer go weird
I think I found the problem. You have to quickly remove the key from the ignition and press on the gas pedal to keep the rpm's around 1500. I don't know why this is, but that works. I think when the key goes from "engine on" to "engine off" it has to go through the "accesories" position. The TT does not seem to engage in "accesories" for some reason. Maybe it's the wiring.
im not saying that to be an ass...
im saying it because i dont have to rev my engine to activate the turbo timer. your wiring must be ****** up, and i dont see how reving up to 1500 will force the engine to stay running .
My TT is fixed now. The wiring was wrong because someone on this board had the wires mixed up on his instructions
Care to elaborate so I can fix mine too? Thanks
The problem was the accesories wire. I had the wrong accesories wire hooked up.
In the instructions that someone had here you were supposed to connect blue wire to blue and green to black and something, but actually it is the other way around......blue wire on the TT goes to black and something on the ignition and green wire on the TT goes to the blue on the ignition, if that made any sence. I was ******* with mine for a few hours b4 Dr.Sound (Vic) came over and we figured it out together. I have hks type-1.
That's it!!!
I have a blitz FATT but the wire colors are the same. I'll try switching the green and blue wire positions.
THX
I just went out on my lunch break and switch the grrenwire to blue and the blue wire to black and white and IT WORKS!!! no more drop in the RPM.
thanks for the info.
funny thing was after I pulled the cover off and was playing the wiring the NEW security guard drove by and told me to step away from the IT guys car and to lay face down until the ploice arrived. I turned and got out of the car, he read my shirt which says:
Richard Taylor
Network Technician.
I said I am the IT guy. he appologized profusly. I'm so sorry sir..I hate being called sir.
sorry to have rambled, I'm just excited that the damn thing works right now.
I can't believe that you guys put up with the TT working like that for so long. I had mine for less than 1 hr and already hated it and I knew something had to be wrong and fix it. I am glad I could help.
wasn't that long. I just put it in this past weekend..so only a few days. but yeah...big difference:D
Similar Threads and Articles
