What's the boost at 6500 RPM? If there's any significant boost, say 5lbs or more, my guess is there's power to be made by porting either the exhaust side of the head or the waste gate, or removing whatever is the primary restriction in preventing gases from getting through the motor.
I would also say if you find it, and remove it, you'll not only pickup power at higher RPM but you should drop peak boost, pickup power at peak boost, and basically increase efficiency.
Just talking theoretically if you increase the efficiency of the motor naturally aspirated, then the turbo doesn't have to work as hard and that's a good thing. Less heat, less chances of detonation, etc.
I would rather go that route instead of trying to cram more air through it with a bigger turbo and more boost.
