What Tire Pressure do you Run in the Winter?
2015 Mazda 6 -- Skyactiv 2.5L NA W/ 91 Octane Tune
Mazda states to run a pressure that's 4PSI higher than what's stated in the door jamb in the winter.
Do you do this? What pressure do you find works well for cold/freezing temperatures, especially when dealing with slick conditions?
Hmm, I've always filled to about 36 psi for my CX-9s, which is 2 PSI higher than what is recommended on the placard. Never had any issues. I only chose 36 because 34 felt a little low to me. I'm interested in seeing what others do.
Will be putting my new (To me) Mich. X ICE XI3's to good use this winter. Will play around with PSI and report.
That doesn't make sense to me.
Testing has shown lower pressure helps traction, so I run around 32 psi in the winter.
