hayula said:i peeked over the guys shoulder when he had a electronic ohmmeter looking thing hooked up to the amp and it read "ouch". whatever that means can't be good!
it was $115 for the driver $40 for install
jflo said:hm....i found the 8w04 at www.tweeter.com . is this sub any good or should i stick w/ the 8w3v2d2 ?
also saw a kicker compvr sub...any comments ?
hayula said:1ST its the dual coil 2ohm. he told me it was being wired to bring the impedance up to 4ohm (so it would be 125w rms as you suggested) so i take it they indeed wired it in serial.
as far as distortion goes there was absolutely no distortion.. just nice tight bass. it's odd i don't know, would a malfunctioning AMP somehow allow a big spike into the driver and fry it instantly? it just went silent no distortion, no click no smoke nothing![]()
Poseur said:Are you certain it's the sub and not the amp? going entirely silent sounds verymuch like an amp shutting off for whatever reason perhaps with the shuffling around, something's grounded out? I'd troubleshoot a bit before calling it dead? Do you have a multimeter or lest light or any confidence to test it yourself? Shouldn't be that difficult... Check for power at the terminal, then at the remote turn on then check the ground wire. If those all check out okay, check the fuses in the amp. If everything checks out okay, then it migthbe trickier... If something's not right, let us know and I'm sure we can help work it out.
Oh, and BTW, not to be a smartass, ut just a terminology check to avoid possible confusion. It's series not serial.
