What size tire with Roadmagnet springs???
supergoose
07' Mazdaspeed 3 Sport
The wheels that I am getting are 18 x 7.5. My ? is, is this the right size rim and what size tire should I use?
I'm running the roadmagnets right now with 18x8 w/ 48 offset wheels on the stock tires. I personally don't know if 225's would fit as the tire right now sits right on the edge of the fender and there is virtually no wheel gap. The only thing keeping the tires from rubbing is the camber of the rear tires. Seeing as you are running 7.5's though, you may be able to get away with some 225's.
Well guys, this is what I went with. The Tenzo DC-6, 18 x 8 with 215/35/18 Faulken tires. They should be here by Sat. and will post pics soon. I went with the flat black with red lip.
Yea, the guy from the wheel place said that with the drop I have that I would have no rub issues with the 35's. Was it a mistake?
Hmmm, the 215/45's should work fine. I have the exact same setup except my offset is 48 on some 18x8 wheels with the rm springs. If you were going to go smaller, I'd say stick with 215/40's.
