what parts are in the 2003 msp???
Secto1
mazdaspeed
(i need to know for my web page)
what parts are used for the following???
Engine-which turbo ect.:
Suspension/Wheels/Brakes:
Interior-:
Exterior- what kind of wing ect.:
Audio:
Miscellaneous:
thanks, secto1....
i know the suspension are tokicos (i think lol), the wheels are racing hart, the turbo is a garrett
Interior-:
Audio:
Miscellaneous:
thanks, secto1....
Turbo - Garrett T25
Suspension - tuned by Racing Beat w/ Racing Beat springs, Tokico shocks/struts. Brakes - 11-inch discs all around w/ Mazda stock pads. Wheels - 17"X ? Racing Hart wheels.
Interior - I believe Sparco shift knob & pedals; now with Mazdaspeed labels on them.
Wing - no clue.
Audio - supplied by Kenwood. Single in-dash CD/MP3 player (model escapes me), 8-inch Kenwood sub, 4 door speakers, tweeters mounted in pillars up front (all Kenwood).
i got it!
ok i got it look
MODIFICATIONS
Engine:
2.0L DOHC 16-valve 4-cylinder producing 170hp @ 6000 rpm and 160 lb-ft torque @ 3500 rpm
Turbocharger System Co-Engineered w/Callaway Cars featuring Garrett T25 ball-bearing turbocharger
high-performance factory air-to-air intercooler
exust-Sport-tuned stainless steel exhaust system with polished muffler and oval exhaust tip with MAZDASPEED garnish
ULEV-B compliance
front:
Racing Beat Tuned independent strut type S
Gas-filled struts S
Stabilizer bar (25mm)S
Coil springs (spring rate 2.59 kg/mm)S
Tokico DampersS
Strut tower brace
rear:
Independent strut Twin Trapezoidal Link (TTL) suspension
Racing Beat Tuned independent strut type s
Gas-filled struts
Stabilizer bar (20mm)
Tokico Dampers
Coil springs (spring rate 2.10 kg/mm)
rims & tires:
Custom Racing Hart 17 x 7 aluminum alloy wheels and wheel locks with Dark Hyper Silver Finish
Bridgestone Potenza RE 040 215/45ZR17 RE040 Z-rated uni- directional tires
Interior:
Cloth-trimmed seat upholstery with sporty insert - MAZDASPEED
monochromatic interior color
Floor mat kit
front and rear - with heel pad and integrated MAZDASPEED logo
Scuff Plates with stainless steel inserts with MAZDASPEED logo
Door handles silver color
Molded cloth door trim - front and rear
Power window switch panel silver color
3-spoke leather wrapped two-tone steering wheel with yellow stitching
Floor-mounted gear shift lever
Shift knob - leather-wrapped & aluminum with shortened shift lever and MAZDASPEED logo
Aluminum pedals - drilled clutch
brake and accelerator pedals with MAZDASPEED logo
Parking brake handle urethane
Center floor console trim - silver color
Shift boot panel trim (MT) - silver color
Black leather shift boot with yellow stitching
Center instrument panel trim silver color
Center instrument panel side treatment carbon-fiber
Exterior:
+++ done for me by mazdaspeed
Audio:
450 watt AM/FM/CD/MP3 Kenwood Audio System - with amplifier
liquid gel 3-D screen
self-hiding and removable faceplate
wireless remote control
and rear glass antenna
7-speaker sound system featuring 4 mid-base speakers
2-tweeters
1- 250 watt subwoofer and accompanying amplifier
Miscellaneous:
breaking:
European spec power-assisted ventilated front disc/rear solid disc brakes with high friction brake pads
Brake calipers - silver painted
Off topic, but I saw your car at Towers last night Secto. Didn't see anyone around it though. Would've said what's up.
i thought we talked there was a black msp next to a silver lexus with bags.
hey well some of us chill at lows monday nights so
hit me up if you wanna chill sometime 561 809-9871 (mike)
secto1, where did you get those specs? the front and stab. bars are thicker then that
27 front, and it's either 21 or 20 in back....is it not? I thought the mp3 had a 25 in front, but the msp had 27. Been a while since I thought of this.
