StuttersC said:The MP3 ECU is not running so high strung that the motor will grenade for running "regular" octane fuel. The cheap gas won't do any damage, the car will back off the timing advance IF it "hears" knock.
That is why it is "recomended" not "required"....
B1GHAM said:Understandable, Im just giving the "if you have the shittiest luck imaginable and God hates you" worst case scenario. Its possible, just HIGHLY unlikely.
With my luck I wouldnt say it, and hed be back in here a week later with a blown motor somehow.
SilentSno said:It will not harm the MP3.
I've ran 85.5, yes, 85.5 for over 3 years now, almost 4.
No knocks, no reduced performance. And saved around 15-20 cents per gallon doing it.
Higher octane does not increase performance, it reduces the change of pre-ignition, aka Knocking.
Over 3 years straight is enough proof for me.
StuttersC said:I would like to see a stock MP3 get on a dyno and do some pulls with high octane gas and low octane gas and see what happens.
That would be the only true way to know if the ECU is really that involved.
SilentSno said:I autox as well, high revs, and still no issues. Still smoke those WRXes without good drivers.Sometimes even the local STIs.
And i'd bet money the differences on the dyno of any car will be within the margin of error for any octane level that the car can safely run without knock.
Obviously higher compression and turbocharged engines benefit a lot from not knocking, hence higher octane.
Search the web, you'll find no proof.
My father-in-law was a top Porche mechanic, I think he'd know something too.
I hate to reference wikipedia, but its pretty accurate.
http://en.wikipedia.org/wiki/Octane_rating#Effects_of_octane_rating
