What is this hose for?
It can and will cause idle issues and can even cause lean condition.
are you guys confused? it shouldn't cause idle issues, and I don't see HOW it could cause lean issues. Its an EMISSIONS issue... to pass emissions, you'd need to completely burn oil that recirculates thru the stock tube. If you put a breather there, you are simply allowing those fumes/oil particles to vent, increasing emissions. Its only for emissions.
There is ZERO change in idle and ZERO change in fuel if you change from a tube to a breather if your engine is in fine running condition.
this is my kinda thread....more info please...? there seem to be some many pro's and con's???(uhm)
BLKZoomZoom can you comment on how it can cause these issues. I am curious and you've always given me straight answers.
It's pretty simple concept. I have seen it cause idle issues and I have personally witnessed the leaning ability it has.
What else is on the Valve cover other than the crankcase breather tube? The pcv. What is the pcv connected too? The Intake Manifold. If you open up the crankcase breather to the atmosphere you are in affect creating a vacuum leak through the pcv into the intake manifold.
The system was designed around the crankcase getting air already metered by the Maf sensor. With the crankcase breather vented to the atmosphere you are introducing un-metered air into the intake manifold. On some cars it won't make as much as a difference as others, but it doesn't change the fact that it is.
If you really want to see its affects get a V6 Passat and pull the oil cap off while its running, it will start to misfire.
on my mam sleeper there is no provision for the breather tube/hose to the intake? i've got the filter on there?
um... if you look closely... the flow of the air for the breather is out. it does not suck in...
and removing the oil cap is entirely different than using a breather.
does this help explain?
Also, Blk I fail to understand your lean issue. A breather does not allow air IN to the engine. The PCV system (duh) is crankcase VENTILATION not crankcase air supply. the air/oil is LEAVING the engine. The only reason OEM recirculates it is because no vehicle would be certified for emissions if it was blowing oil oil out of the motor... make sense? so having a breather vents the oily smoke out to the air instead of reinjecting it into the air stream for a complete burn
Start your car up and pull the tube off. Tell me if it is blowing out or sucking in.
Why is taking the oil cap off different than throwing a filter over a hole?
The breather does allow air into the engine. The pcv is hooked up to the strongest vacuum source in the engine. Air will take the path of least resistance and instead of the pcv taking the air from the crankcase it instead will suck it through the breather.
Yeah, they are.. the same piece of aluminum. He'd know that if he had ever taken the valve cover off.
It gets sucked into the intake manifold. Thus adding un-metered air into the engine and possibly causing idle and lean(er) conditions.
have you looked at the underside of the valve cover? do that then tell me if its the same.
huh?
The baffles are so that oil doesn't get sucked up.
Yeah that's what it looked like. Either way, I ran a breather filter for almost a year and really didn't notice any difference.
during extremely high load, if the volume of blow by exceeds the ability of the PCV valve to draw in vapors, the excess blow by flows THRU the breather hose to the combustion chamber OR BREATHER. If using a breather, the excess blow by simply vents to the atmosphere. the pintle in the PCV controls air that enters the crankcase. only a small volume is pulled in if using a breather, not usually causing vacuumm concerns due to various check valves in place.
