What is overboost? In regards to removing cat from DP.
I would too, and I will down the road. Just need a quick fix until I can come up with the next round.
i recomend that you skip the test pipe altogether until you can get the dp and get an intercooler instead. you'll get your 20hp, and you will run crispy cool and silent.
The beauty of the test pipe is a quick mod to add some responsiveness in acceleration. You can always sell the test pipe after you pick up a DP anyways.
This was my thought process as well. Probably going to be next season for DP unless something drastic happens.
the top mount is also just as quick to install, and adds 20 real hp. and the intercool only improves the quality of the car, it doesn't remove something vital in order to perform. turbos need cats.
