Ltlrdwagon
- 02 P5
how did you mount that rear bar? interested in seeing since it was designed for a sedan.
I fitted it to the forward most strut tower bolt. If that's not right, uh oh
What's the mounting point in a sedan that this bar would use?
2 bolts on the rear parcel shelf.
I don't think there is a synchro to help put the trans in reverse while rolling. Sometimes, while stopped, I can't get my car in reverse and have to let the car roll a few inches so the teeth on the transmission line up and allow it to get into gear. I've hear the noise from my clutch too, it turned into a squeaking and then went away. I'm not sure if there is a grease point on our clutch or not
So grease goes under the dust cover?The clutch release is contained withing the housing. That boot is a dust cover on the joint. There is an arm that goes inside the housing and pulls the clutch
Right, so how do I make the clicking stop? Its not like its a problem, just annoying.no way, the only grease is a light smear on the spline of the input shaft when clutch is replaced, the thrust and spigot bearings are normally sealed units as grease/oil on the clutch will cause it to slip.
On the occasions where I have trouble getting her into Reverse, I just keep the brake pedal down and the shifter in neutral and let up off the clutch for about a second, then push the clutch back in and try again. I seem to recall seeing something in the owner's manual about it and that was the suggestion it offered. I think it's probably the same remedy as you're doing, except without rolling the car.
