i tried to fit my new fd wheels. need spacers +new rubber. im gonna sell my 205/45 and 225/50 and get some 215/45 +10mm spacers.
If you get anything more than 5mm you need extended studs. I recommend going with 5mm and 225/45's for the tires. With that setup I'm about as flush as can be.
You got a better option? Some of those fancy levitating wheel weights maybe? 0.o
Steve Jobs let you in on the secret too??? (lol2)
Nope, unfortunately you're either getting miniature, flattened thumb tacks in your wheels, or you have jumbo paper clips on them. I prefer the clip on ones, as long as you're not having to worry about clearance to the strut. The little tack holes left by the stick on ones makes my ocd go nuts... (shrug)
Matt V, hey i rethought about it and thats exactly what i will do. 225/45 +5mm. I was going to send you a pm about if you had any problem fitting the lugs with 5mm.
Matts tire/wheel/suspension setup FTW. (2thumbs)
Did you ever get a front grill, Matt?
Who sells those red circles of vinyl for the taillights? WAY back in the day I ordered that vinyl direct from someone selling it in sheets, but I can't seem to find where I got it. I covered the orange on my RSX-S's taillights for a better look. Anyhow, was going to see what whoever is selling those is charging...
Thanks!
not really, you can fit 11mm spacers on there, just barely, so id say anything more then 8mm and you'll need extended studs, unless you get the ones with built in studs that is
i really want to jump on those FD's but not sure if I like them enough. I really really want those Enkei's that are in the FS wheel section but cant spend that much on wheels and tires. rather get myself a header and make it louder :D
well i drove it 3 hours back home, man this open midpipe is gay, im putting my megan racing back on tommorrow once i clean it up a bit
also did a boost leak test and used soapy water this time with it, found 2 leaks by my injectors and heard another one coming from below (egr?) gotta find a way to fix those tommorrow too
seems like all my issues with going turbo are coming from leaks or bad sensors
Bluebatmobile.net. I think they run about $14.
I rotated my brake caliper today...when I did my rears a month ago, I accidentally turned the caliper and twisted the hose, then reinstalled it that way. After some adjusting, all is well. Still need to decide if I should readjust the pad clearance to the rotors...I think there's too much.
Yes it is, sadly. :(
Lewis, yes I did get a grille. It's a DGM replica but I think I'm gonna toss it for a factory grille.
Matt you really need to take it back to the shop and demand they do a better job. That is piss poor. The paint looks good but it is so horribly matched that it's making me plain mad.
Installed a 6 wiper today- thanks to Hornsfan for the sale! Will get a pic up soon once I can clean my car!
Also removed the door moldings on the driver side- it was hellish until I went and bought a 3M Stripe Off Wheel for my cordless drill- HIGHLY RECOMMEND!!!
It took me 45 minutes to remove the first 8 inches of glue (and chipped the paint way too many times) while using a credit card, fingernails, 3M adhesive remover and a heat gun. But it only took me an hour to remove the entire rest of that side of the car using the 3M Stripe Off Wheel. This thing is the shiz. Will do the other side tomorrow.
I would wait David, it's supposed to rain until the end of the weekend.
Also, I installed a 320GB external HDD in the car today. I have all of my music on there, it's quite awesome.
most likely lol
and i forgot to post this last post, removed cruise control from the engine bay, still have to remove the steering wheel switch tommorrow
and i STARTED STRIPPING THE STOCK HOOD :D rust here i come
What did you use to strip...I could of sold you this can of stuff...it was SUPER expensive and I have a ton left...mine is rusting, but even following the how-to's online it takes a lot of time...it is coming, but slowly...
My Rear strut tower bar(mx-6) came in and allready installed it,i can allready tell a difference....:) cant wait to put my rear racing beat sway bar!!!! and my endlinks
