she's the one that said she wanted a header.
Plus, her MSP lip is her anniversery present, and she is happy about that!
Ok, for the 1st time in a long time I had to go in and clean up this thread. I don't actually enjoy having to "do" work. If you want to be THAT off topic, go play in TLT. Now sod off!
you wanna start again? Let's take this outside!!!
and to stay on topic, i just sourced a replacment OEM fog switch and fog relay! Wewt for being able to keep all my factory fog stuff for when i can source something to use in the MSP lips!
Sorry I guess that was my fault!
Back on topic...Had to replace my 2nd low beam bulb in 6yrs.
Also have a polished perrin fuel rail on the way!
I just put in sylvania silverstar ultra 4100 something $50 for two...the only H7 they had at the local auto parts. Before this was what the car came with.
Have you redone your grounding or other wiring. Because most proteges eat silverstars.
Edit: Nevermind, I was confused. Good luck with that...
mine ate silverstars in no time. keep that recipt, cause you'll need it
Also, just got conf. that the white MSP lip is headed out via fedex today and should be here by the end of the week
Mine did as well....as a matter of fact three sets in under two years (one set being the Osram's which are supposedly better than the regular).
Mine loved the stock bulbs until I moved to Alaska.. popped them both within a month of each other, then I had my replacement pop a couple months after that... I was going to blame Alaska for my woes.
Now that I went HID, I haven't had ANY problems with bulbs...
My bulb that just blew has been in there since new 6yrs ago! I already knew the silverstars commonly don't last but i had no other choice.
