I recently upgraded to AWR endlinks front and rear w/ sway bar and plan to change my Tein SS coilovers to BC ones.
How they working out for ya? Keep us posted of how they work with the BC coilovers later on since some have had problems with AWR endlinks, dunno if with coilovers or straight strut/spring combos.
I couldn't keep my rear AWR endlinks quiet no matter how I adjusted them. I did the install with the wheels on the ground, I made sure there was no binding during the install and everything was bolted up super tight. It would be quiet for about two days and then the clunking would come back. I switched back to the stock endlinks (had to order new ones) and everything is all quiet now and the performance is still there.
i fixed mine the other day, i didnt do it with the wheels on the ground the first time so thats why mine was making so much noise, so i made sure both wheels were on the ground and i sprayed the part of the endlink that rotates in the little banjo bolt looking thing with some teflon lube, it wore off after a day but it doesnt clunk or anything
it just makes creaking sounds when i go around corners slow, gotta put some heavy duty grease on there
ditto
mine makes weird clunking noises under braking? like a bad axle but nothing is torn or ripped or messed up at all? no way its too low..... i have no idea
