I'm SO excited!
So my P5 started making an "odd" noise going down the road about two months ago. As the noise worsened I figured my luck it was one of the new wheel bearings going bad, however, I also thought it could be a wheel-balance issue.
After swapping on my stocker peeling chromies I did the wheel bearing "jerk" test to the raised wheel. Not sure why I didn't do it with the 17" Mazda 3 wheels on, but I didn't...
To my surprise the drivers wheel shook up and down round and round and all over. Awesome, I thought, starting back to school and having two trips planned, I was going to have NO time to work on it. So I parked it and have been driving the bimmer for the past month. Afterwards the thought crossed my mind that the new axle nut might have come loose and might also be causing the drivers-side output shaft seal to be leaking. Which it wasn't before changing the leaking passenger-side, it started leaking afterwards. But typical male, I thought, oh no, surely not, my mechanical work is top-notch, lol...
A month passes and although I feel sick and should have gone to bed, I wanted to feel productive and just put the car in the air on jack-stands. And to my surprise, after pulling off the drivers-wheel, the axle nut was SO LOOSE! Scary loose. I swear I torqued that biotch down with an impact. AND dented in the indention part...
So I'm exhausted after that bit of work because, as I said, I feel like crap. I don't have time to be sick with full time work and full time school, but I am excited to know the problem will most likely be an easy fix. I say most-likely because everything I've fixed on this car has taken twice as long and cost 2-3 times a much...
Hopefully wake up tomorrow feeling well, run to work to fill up an air tank and borrow the impact, maybe I'll have her back on the road tomorrow afternoon.
*crossing fingers*
Question: Having driven the car for at least 500 miles in said condition, will the front-end need to be re-aligned when I get her fixed? Nothing suspension-wise has moved, to my knowledge, just the axle and disc/hub have come loose. Thoughts?
