shane02pro5
25ish_psi
- New Caney TX
8-10mpg romping on it when I was tuning but 30+ cruising...mazda tune not so great at times!
I wonder how much mileage would improve on the highway if the MSP had 6 gears....I get 31-32 mpg as it is lol and thats averaging 80mph
That's a good question, although with the 6 speed, they'll probably put the gear ratios closer, leaving you at about the same ratio as your 5th is.
Or just a better 5th gear. 3000 RPM @ 60mph/100kmh is ridiculous.
So after spark plugs & wires & atf change, my mpg improved from 16mpg to 20.3 mpg. I guess it's some progress, better than nothing. Or maybe it's just the warmer weather.
But every time you downshift to accelerate you are burning more fuel. It is also good to have a little bit of power for passing and being able to maintain speeds going up inclines without mashing on the gas (and burning more fuel). Cruising at 3000 RPM puts you almost at the peak torque RPM.last gear should be a cruising gear. who accelerates in 5th or 6th?
I don't know, I tested puttering around at around 2000 RPM for a tank and I found I got much worse gas mileage than keeping it around 2500 RPM and above.
Now my truck is completely different. It doesn't like to be above 2500 RPM too much at all and 2000 RPM seems to be the best cruising engine speed.
yep. They did that with the miata 6 speeds. Cruising RPM was pretty much the same, but the 'tweeners' were a lot shorter.That's a good question, although with the 6 speed, they'll probably put the gear ratios closer, leaving you at about the same ratio as your 5th is.
Just like the S2k... only the S is a 6 speed. That's the only frustrating thing... why make 6th gear so short? I did the math and, assuming it would push the wind up to that speed, it would top out @ redline in 6th at 167, give or take an MPH. And it's not like it's a transmission that's not an absolute joy to flick a couple gears lower to blow past someone. 3rd gear at 60mph = VTAKZ! Really fun for blowing past someone that's been hogging your laneBetter than my Civic. 4200 rpm at 80.
