Really tempted to snag one of the 2 sets of awesome cams in the for sale section right now... but I need moar moneyys.
Yeah I'd probably grab the twiggys. Cheaper and more lope. You have to use adjustable cam gears to dial them in tho which can be a b****.
Question. Since I pulled the SMIC can I run two slim fans smaller than the stockers so they just cover the radiator?
Also which way to our fans flow? Pull or push?
They should be pullers, and yes you can run them like that. You can just cut the connectors for the stock fans off and wire in the new slim fan directly to the stock wiring harness.
Do I want the ones that come with the universal "thru radiator" mounting kit that look like zip ties or the ones that come with attachable mounting tabs?
Let see, friday I ordered Fortune Auto Coilovers :) Also on friday I took off my rad, and took my turbo assembly off to fix my downpipe issue (was only being held on by 1 bolt) My luck though putting it back together I had one of my bolts 1/2 way in and IDK why it got stuck. And i tried to take of off and the bolt just twisted and broke -_-' after 3 hours of drilling it (took that long cause one of the drill bits BROKE on the inside... and they are not easy to drill though hah) i got it working again and put everything back together.
But on a side note
*Clears throat*
I WON 1000$!!!!! Im like awesome! First time that I can remember ever buying a scratch off ticket legitly. And I won. Awesomesauce!
i actually just put the slim fans in as well.
at the local sonic cruise-in:
How do you keep your car so clean 2088?!?!
in florida is actually not that hard, except i have to keep washing the dam sap of the car every week. also clay bar should become your best friend if u want to keep it clean. also have u heard of the Ice, synthetic car wax? that stuff is awesome, it doesnt leave residue on plastic trim!
How did you mount them? Do the "through radiator"things work?
and yeah the "thru radiator" zip ties work just fine. I got 2 of those mounting kits with my fans, so im actually saving one for when i get my full size radiator.
