Pulled my heatshield to locate my exhaust leak. 1 Broken stud, several loose.
Tighened them all down. Snapped the head off another one in the process.
Manifold is coming off next week to replace studs. Good thing is even with two broken studs, my leak is gone. Hello consistent boost.
yes, Carbon Hood, and trunk,
soon will have Carbon Roof, Sideskirts, Front lip, and Rear lip ;)
Oh, and 1 off carbon fenders aswell ;)
I know I know, im a carbon *****.
like this.... sum pics of teh other ride. let me know wat yall think
HAHA, NO to the 03 wing, I want the 2003.5 wing, but get it overlayed in carbon Teehee :)
DUDE seriosly stop stealing or trying to ruin my ideas.... I have aready talked to a place to have the spoiler overlaid in CF... NOT CHEAP.
I like you're msp a million times more than the SRT<-ugly car imo, but i bet it goes fast in a straight line!
im not taking anyone's ideas, they are all my own. and Its cheap for me cause I have friends that do it. I will prob make 1 off carbon fiber door inserts (the inside) one day.
I know man, just giving you a hard time... and I need to find friends with sweet hookups like you have... maybe I just need to find friends... and wow, you like CF dont you lol
ok folks i need some help
i have two check engine light codes.
P0301
Cylinder 1 misfire
P0660
Intake Man Tuning Control CKT Open (bank 1)
changed the spark plugs about 3 weeks ago
any help on what i need to fix it?
I'd pull and inspect the plug first... it wouldn't be the first time someone installed a bad plug. Next I'd check the wires.
P0301
Cylinder 1 misfire
P0660
Plug wire might be loose as well as cyl1 has the plug boot not a coil. Also the p0660 sounds like a vtcs or vics solenoid not sure which of those that is going to be associated with.
I wouldn't rule out the possibility that one problem is causing both codes. If swapping out plugs doesn't fix it, then swap out wires. Check contact points on the wire and clean if nec. then swap it with the other regular plug boot wire. If the code hops to the new cylinder, its the wire.
