Well I finally past the 50,000 mile mark. Keeping my figures crossed that it won't have too many problems. Emphasis on the "too many."
ouch!
I don't think I'll ever get rid of the turkey. I just had a HKS SSQV welded in and I still get a little turkey at low boost levels. It's using the brake booster as its vacuum source too. It probably has to do with the 8 miles of other vacuum lines I have under the hood.
Yeah, ever since my AFC and 626 IM install my vacuum lines have gone all over the place. It doesn't help that I have a line the runs from the engine bay, into the cabin and then over to the passenger's side (probably like 6 ft!). Once 505zoom's new IM comes out I'm going to be motivated to clean things up quite a bit. Thing is, I still probably won't need a vaccum block...well, that's good to know...at least now if my car still has the turkey, i won't be standing under the hood scratching my head.
ahh, so AC is down also. Anyone have a how-to on replacing it yourself? or would it be too much trouble?... i looked through the how-to threads and didn't see anything.. called two shops and got a quote for $103 and another for $125.. really don't want to spend that if i can do it myself...
dude if you've got a basic set of metric sockets and box-end wrenches then do it yourself, its really quite simple
just replace both belts at the same time........basically you just gotta go up by the power steering pump and loosen it up on top and on bottom, which takes the tension off the belt....swap the belt and install in reverse
I can't recall if the belt for the alternator is on the inside or outside, I think it's the inside...but if you replace that belt as well then it's basically the same process as the power-steering pump
I'm pretty sure all you need is a 14mm box end and a 14mm socket actually lol
