I might have to screw around with some of the other presets that are on the ss thread in here. I've been running it like that for a year now, but I justed went to 9psi and finally installed the uego wideband.
I'm not sure why but my car started to run richer after a while and reloading the map onto the AFC made all the difference in the world.
It is worth a shot to re-load the super stock map or even try the FMIC map. It sounds like you are on the stock tune with afr's that rich.
why do people insist on using other peoples maps instead of making your own...? every car is different, especially when they have different mods, your car will react differently and you could be doing damage without knowing it.
exactly. load a base map, then modify it. dont just flash and go. flash a map that is similar to your mods and then tamper with it.
looks like about an inch lower than the subframe, is that correct?
That's what I plan on doing. I'm not just going to slap a random map on. I don't have data log option so I need to run it under load with someone in the car and adjust it as we go. Phen and I are going to mess around with it later. I'm just glad I'm running really rich rather than really lean.
I'll measure for you when I get home tonight.
Has anyone replaced the factory alarm/keyless entry system? The one on my black MSP appears to be all whacked out. I might take it to the dealership to see if they can tell me what's wrong.
I replaced mine with an aftermarket one after mine went funky on me. Don't forget to check the fuse, it's under rear hatch wiper or something like that in the manual. The first time I had a problem it was just the fuse, the next time it was pretty much shot.
dealer wanted to charge me $80 to re-program it...
there is a re-programming guide somewhere here on 247 its pretty easy to do. i even bought another one off ebay and programmed it myself.
Um, that's what I did? I chose the FMIC map which lists basically the exact mods I have and the AFRs are solid. Been running it for over a year no problem.
finally did my first track day
<a href="http://www.flickr.com/photos/jonashaffer/9409401853/" title="AMP Adams Time Attack Mazda Shootout 7-30-13 by jonashaffer, on Flickr"><img src="http://farm8.staticflickr.com/7417/9409401853_76b0b99954_z.jpg" width="640" height="425" alt="AMP Adams Time Attack Mazda Shootout 7-30-13"></a>
Think my tires have a slight flat spot from sitting for a few months... get a wump wump wump wump sound when driving, especially at low speeds....
Hopefully it wears off... these are brand new tires....
unless a s*** alignment could cause that....havent had the car aligned since doing all the suspension work.
put it up on jack stands and inflate the pressure to 50-60psi and let it sit overnight. thats what we do with all our new car deliveries that have been sitting on the showroom floor for months. always seems to work without an issue.
sweet pic. i love the poke from your wheels haha
