- 1989 RX-7 GXL Blaze Red
True, but 124 plus shipping unless I can talk to them
If you look at the top of the CR3 site you can see that all order ship free
Hmm well then that don't sound like a bad deal then
There's no reason to not be 14.7 while cruising. You'll get the best mileage there. Mine sits at 14.7 all day cruising.
youre gonna want a 12.0 to 12.5 at WOT. if its above that then dont go WOT. cruising should be about 13-14
Yea, I'm in between 14-15 while cruising, but WOT I'm at 10 or under and just dumping fuel.There's no reason to not be 14.7 while cruising. You'll get the best mileage there. Mine sits at 14.7 all day cruising.
I mixed it up as alwaysI know I would rather dump more fuel than run lean. Just didn'texpect it to be running that rich.
dont you have a ssafc? are you running whatever map came on it when you got it?
I do have a ssafc, but it is a v1 and yes I'm running the map that came with it.
ya? its never done it before and i dont have any tunning done(yet)stock ecu. Crap..oh well guess il have to get that sorted out
It is worth a shot to re-load the super stock map or even try the FMIC map. It sounds like you are on the stock tune with afr's that rich.
did it start happening when you switched gas stations? what octane are you running? what is the ambient temp like? it could be hot hot air going in and causing it to run bad if its really hot out. or it could be coil packs/plugs going bad.
your msp does? oh wait you mean your msm..... GTFO phen.
hehehehe im kidding. my protege cruises at about a 10.5
