So I've got a question, will a 1995 ford probe engine be interchangeable with the mazdaspeed protege engine? I'm asking like if all the mounting points, plugs, bell housing, and etc will fit. I'm asking this bc I have the engine from the probe, and if its interchangeable ill forge that engine, swap all electrical components over and be set... So are they interchangeable?
Thanks in advance
block yes, electrictal i doubt it. forge the block, swap the head etc.
ugh so tired. Where to start....new passenger side axle in,font hubs are back on,coilovers are on,works are on,aac bumper brackets are on,bumper is on but not completely tight, trans fluid is in, oil filter has been changed and new fluid put in,turbo timer fully functions now. Over all she will be ready to run next weekend And i can't wait
Ok cool... Now what's the best Mazda 2.0 flowing head? I'm looking to do a pull n drop with no down time of the car...
I believe they are all the same, just different cams and how that info is relayed to the ecu. Best thing to do is have one ported and polished
Changed oil, plugs,rotated tires, tightened valve cover and IM bolts. Time to put her away for the winter pretty soon!
Got the motor and trans out, headlight, radiator, and Fmic (le sigh) out as well. Also the turbo mani, Silvia turbo, pope dp and the dump pipe has been pulled and sold for parts for the exterior parts I need to get the repairs done. And since I'll be changing to a t3 anyways
how did the wheels fit?
I always bleed all over my engine bay.
Took out my first cf fender out of its mold today. Turned out pretty good, but I need to fix some little imperfections and give it a good wetsand and buffing :)
