- 03.5 YLW MSP
Don't think I've ever seen one.
Its just a mini truck
http://image.minitruckinweb.com/f/18114430/0907mt_04_z+1992_mitsubishi_mighty_max+custom_truck.jpg
Those are sweet little pickups and take one hell of a beating as well!
ordered redline trans fluid and amsoil engine oil also cut my last 2 intercooler pipes and got my wheel bearing replaced. Oh and I rode in mebarsh's new Audi s4 boy is that thing fun
you don't own any mazdas anymore mebarsh still has a Msp lol.
if fuel injectors aren't seated properly, could that cause a vac leak? Im bored so Im going to mess around with the car a little bit.
You bet they will.
well, just because I was bored I decided to take the manifold off again. I can see a little bit of daylight around the plastic rings on the injectors and the flange on the manifold if I hold it towards the sun. It isn't a lot, just barely visible.
They need to be tighter. Try removing a washer from each side of the rail but make sure you don't crush the injector tips. You want to squeeze the seal and still be able to gently rotate the injector.
o ya they do.. been having problems with mine sealing. Pick up some 626 injector seals... way cheaper then the ones for the protege and better.
ThaznksLove the yellow on the MSP. Very Clean.
next Saturday I drive to alt to get my frame and the msp.will be disassembled that Sunday. Look for pics to come.
