how come?
I've had the clutch off about 10 times and never had to use an alignment tool. I just eyeballed it.hey weird you are posting about those, i've had them bookmarked for a while planning on snagging them up this week... until i saw that price increase! wtf?
EDIT:
also, i'm installing my clutch this week finally... exedy stage one + the fanzdia flywheel. i can't find the damn "alignment tool" anywhere online. wtf do i do? (my buddy who is helping me said i def need it).
EDIT:
Good luck with that.
Unichip can actually tune ignition, not just retard it, which is all the SSFTC can do. If you were in an area with an authorized tuner I would definitely reccomend the Unichip. It worked great on my car, but the nearest unichip tuner to me is like 8 hours away, so I had to go stand-alone (well parallel EMS if you want to get technical).
I guess what I'm really for is something with the most capabilities to have a performance shop tune.
Neutral safety switch or wiring is a documented cause of your complaint. See if there is a P0507 stored in the fault memory.5th time pulling this tranny swapped in a new clutch and in neutral my rpms hover about 2k push in the clutch and rpms are normal again. My old clutch was chattering toward the end so I had to raise the pedal a bit to allow a little more disengagement or it would bog the motor on occassion. I brought the pedal back to normal and every other position and still WTF! I had to resolder a wire to the sensor on the front of the tranny... thinking maybe thats the neutral safety switch and didn't get a good enough solder joint.
Sensor on the front of the tranny is the backup switch, nuetral switch is on the backside under the speedo connection for those without abs just fyi
