Started wrapping my interior![]()
i once owned a suit with that same pattern
you know map b isn't used right? I would have just lowered them starting where the boost starts at, also maintaining your AFRs at the same time though
Cool, thanks! Any input on changing values by .2 across the board? Would that be too much to start off with?yeah, write to ECU. name the map so you can keep track of which map is what
That was the first thing I checked afterwards. It wasn't set up correctly, so I changed it all, but have recorded data since changing it.your afc may not be set up completely. It's been a while since I have messed around with mine but check your system settings and engine settings under options in the r4 software. What do they say?
offset and drop?
18x7.5 +45 w/ 225/40 tires , on Espelir springs & stock Tokicos (rolled fenders, used to rub, or more like pop in turn).
Thinking about going to Ground Controls with custom spring rates soon though. Really want to get some Koni Yellows to work without hacking a strut housing.
-1.4" & -1.4" so about .5" lower than stock RB springs.What kind of drop are the Espelirs? I also inputted your tire size width ect for a complete wheel spec on that.
