I'm hoping it won't either. I used the same stuff on my RSB and FSB bushings for the Subaru and they seemed to be OK.
that looks like un-coated, welded, steel to me. The "bling" is an armor coating that keeps it from rusting and is very resistant to scratching and doesn't degrade the steel's strength. Nickle-plating and (maybe?) galvanizing can weaken the part.
got the car back from the body shop last night...then my almost-3-year-old son said to me "don't get a booboo again!"
Maybe he thinks he'll be inheriting the car one day. Good lookin' out![]()
installing my coilovers and have already hit an impasse! anyone know how to remove the bottom of the front strut from it's perch? i can't get it to budge an inch...
Here's the method I used to use with my Focuses (which have a nearly identical design):
1. Loosen (but do not remove) the upper strut mount bolts.
2. Remove the bolt that tightens the knuckle around the bottom of the strut.
3. Making sure the car is secure (and not likely to fall off of your jackstands), use your foot to kick the hub downward until the knuckle comes off the strut.
Alternatively, some people have used the scissor jack to spread things apart, by placing it between the bottom spring perch and the knuckle and jacking it up.
Ok, let the laughter ensue, but today I installed an old Blose Acoustimass sub in my spare tire well. Believe it or not, it is super light, handles 200/channel, fits, and sounds great! Now it doesn't perform like my Hifonics Olympus 15" but it weighs about 100lbs less! It hides away completely and honestly reproduces respectable bass. I still have to hide the wires and vacuum but you get the point![]()
I like it! Stealth bass FTW.
