I watched/heard my wife pull out of the driveway and turn a little too early, dragging the front bumper straight off and through the curb.![]()
ouch. (peep)
Changed the front and rear sway bar bushings. Hopefully that will cure cold weather clunking from the front. Although the front bushing still looked in pretty decent shape, so who knows.
. Luckily bumper covers don't cost too much. Btw, does this mean the spoiler is finally going on?
A lot of folks are over looking this awesome low budget yet safety and performance contributing mod.
Some questions:
What did you do with the backing plate/dust shield? Nothing, bolted right up with no rubbing or fitment issues.
What pads are you using (front and rear)? Used the Centric (Stoptech Street, Para-aramid material)
What rotors are those?The Powerstop Drilled and Slotted - JBR1116XPR for the rears and JBR1315XPR for the front.
ORLLY?! That is very interesting. The shield definitely would not fit on my 08 Sport; there were two issues. The radius of the lip on the bottom is not large enough to clear the larger MS3 rotor and had to be bent/straighten/cut off to clear. The MS3 rotor rubs against it and had to be stretched to fit for this pic. Theres also a little nub protruding on the bottom of the shield that obstructs the caliper body where theres no way it can physical mount without bending it away or cutting it off. The top nub was also awfully close to the caliper body so I decided to nip it off as well.Super easy and not that expensive. For those that want to go the quick and cheap route you can do this upgrade on the front for about $250 total for replacement parts, not including brake line upgrade.
Centric reman calipers that include the brackets. Send your old calipers and brackets back for core refund. Net cost about $130 for the pair after core. Rockauto part number 14145112 and 14145111. The 5's existing caliper bracket bolts are the same as the MS3.
Centric rotors. Rockauto P/N 12145078. About $40 each
Bendix pads - Rockauto P/N RD1044. About $30
ORLLY?! That is very interesting. The shield definitely would not fit on my 08 Sport; ...
Or is this an undocumented change for lucky 09+ owners along with your fancy stock oil filters. Makes me wonder what else is undocumented (GTs have better horns than the Sport/Touring factory alarm). Did you try putting on your stock wheels? I will be quite upset (at Mazda) if your stock rims clear the caliper body. I had to use spacers. Im hoping my current GT is somehow more like you 09 and less like my previous car.
Also, thumbs up for keeping the sleeper look! You are all set to go racing!![]()
I'm using stock '08 wheels. The issue is not the rim’s width/diameter. The issue is an unfortunate mix of high offset on the OE rims, design of the spokes being too vertical ('08 rim), and the MS3 caliper bodies are bulkier. The spokes end up rubbing against the caliper body, front facing, and the rim cannot seat flush to the hub –off by just by a tiny bit. Need spacers to clear the calipers.I didn't recall having that radius on the lower half of the shield that would cover the lower edge of the stock rotor like yours. Likely was a change on 09 or later. The shield on mine is pretty much flat. I never tried the stock rims but am running a 17 inch wheel now. It is a 17x7.5 w/ 42mm offset. Seems to have plenty or clearance. I've heard of some MS3 guys running 16" wheels for track days also. What wheels are you using? I Am thinking they'll clear the stockers.
