I was messing around with the height settings in the rear a lot yesterday and I found out that when the rear perches are at the same setting, the Passenger rear is about 0.5 inches higher than the other side. I then decided to try the extremes and set the rear passenger all the way down while setting the rear driver side all the way up (there is only a 0.8 inch variation in rear perch height adjustments). This made things turn out pretty even so I left it like that.
When I checked this morning before leaving for work, all of my wheels had about a finger gap with the fenders. It seems a little weird that my driver’s rear perch is set all the way up while my passenger rear perch is set all the way down. After breaking out the tape measure, the passenger rear was still about 1/8th of an inch higher than the other side.
After my drive into work this morning I did a quick finger gap check and now it seems that the drivers rear is 1/8th of an inch lower than the other side. I might not be on level ground so I'll check again when I get home. I have a feeling that I am seeing a spring settling discrepancy. I am going to check things out periodically and I assume I will end up adjusting those rear perches a lot. Good thing it is really really easy to do. It takes 5 minutes tops to adjust the rear height.
As far as the low speed creaking, have you checked your end links? You have to remove them from the lower control arms to install the rear springs so they might not have been put back on correctly. That'd be the first place I'd check. If it’s not that I'd check the top shock mount bushings. With the V2's they need to be drilled out so they might need some lube or something.
