Weird Coilover Rear Height Adjustment Issue
Ok, Just got finished messing with the rear again. I basically disconnected all six bolts for the RSB, swapped the springs and started over. Along the way I was taking measurements from various parts of the frame to the floor and everything was basically the same on both sides. Before putting the RSB back in, I made my height adjustments with the wheels on the ground. When I took measurements, it looked like the passenger side was about 3/8" higher. There seems to be a weight bias towards the drivers side. I then made my adjustments to the passenger side (about 5/8" more thread showing) and everything now seems level (+/- 1/8"). Once that step was done I bolted on the RSB with the car on the ground.
