Weapon*R Engine Damper In stock.
Status
Not open for further replies.
wrleo
We just recieved our Engine dampers for the Mazdaspeed Protege.
MSRP is $200.
Anyone intrested PM me or call us at 650-877-8280.
come on, you expect people to buy this when you don't even give a picture, info, how it works, etc? get AV status first.
I did say give me till today to post the pictures and info.
I just got into work guys, give me a break here.
The high quality WEAPON*R Engine Damper mounts in between your vehicle's engine block and firewall to effectively control horsepower and torque. Keep your motor supported as you slam through those gears while adding a nice show piece under the hood. Creates less stress to engine mounts, giving you more power to the wheel!
Great.
Question: Does this fit with the the stock strut tower bar?
this fits with the stock strutbar, but you need to notch it about 1/4" on one point of the stock strutbar.
For other strutbars you will just need to add washers on the back 2 bolts on the strutbar and then put this under your other strutbar.
Great, notching a strut bar is wonderful for the effectivness of it! Or are we talking about notching the bracket?
Not trying to (flame2) and I like the idea, but some people aren't going to want to mod stuff.
You notch the Stock bar slightly.
but if you dont want to do that then use some washers to space the stock bar up slightly.
Status
