I was following neox2.0's write up on the part for the water feed and I can' t seem to find the connection he's talking about. I have something taken off and i'm not quite sure if it is it. I have a couple pictures here to show you what I'm talkin about. If anyone can help me, please do so! It would be very much appreciated! and the first picture I have there was stolen from Brian MP5T by the way
Trevor
"--For water feed, on the back of the block (just above the oil filter) is a connection where you will mount a banjo fitting. You will use the oem fitting, which basically extends the already existing fitting out further, coupled with the banjo->hose fitting from ATP turbo. You will attach a length of 3/8" rubber hose from the ATP turbo banjo fitting to the water feed metal connection on the turbo."
Trevor
