wat mods do u have sitting around to install?
blkspdfreak said:
custom turbo back, hid's and rims(cant decide), grill.
ur car is sick !!! (omg) monster job on that one !!(first)chapeau
Special..Intercooler Set-up Waiting to pick it up from the shop once the pipes get back from Ceramic Coating.
Grounding Kit
And waiting on new tires..
Waiting to install the factory exhaust so I can go get smogged...
THen, let's see,
Pullies
shorter springs
put my Sparco seats back in
Exhaust dump
GT Spec lower tie bar
Extended wheel lugs
Rota Slipstreams
Non-a/c belt
Hmm...that's all I can think of right now since I'm not at home looking at all my parts laying around.
Britt
^^ do you know the belt length for a belt to eliminate A/C? I don't have the A/C fan on my car anymore (stock p5 one is massive and wouldn't fit with the msp turbo kit) and don't really care to hook the a/c up again
i trimmed the s*** out of mine becuase it was close with the Ion FMIC kit. I dorve and wne tin my girlfriend's Ecilpse turbo and **** that s***..it was so ******* cold in that b****..given that i'm in oklahoma right now where the highest it's been in the past week is like 33....and low teens every night.
Well, lots o' stuff to be installed and the list is really quite long. Instead of listing my new stuff here I'm going to make a new thread soon with cool pics of the progress...:)
what is it with protege guys and collecting parts? as a community we could build a 550hp protege just from what everyone has laying around.
the only thing i have laying around is the mad tyght forsale mod. its the only mod that pays ME, usually the other way around.
boost controller and boost gauge were installed already on saturday along with irridium spark plugs with magnacor ignition wires (8.5mm).
I still need a few couplers and Ill be ready to install the following:
* front mount intercooler
* turbo xs BOV
* little engine breather
* intercooler pipes
sorry to jack this thread yet again, but for the good of the community I wouldn't recommend a breather, not sure about stock engines but i smelt oil under idle and parking lot driving conditions when i had a breather. if that wouldn't bother you then go ahead.
the only reason I bought the breather is because my piping does not come with the premade hole for the hose to plug it in.
yeah my intake has the hole for it so I hooked up my old breather hose.. one of these days I'll install a catch can or something so it isn't spitting oil into my intake.. I've been checking the inside of the breather hose every day and it doesn't look at all oily so maybe my breather is being nice.
I thought I was the only one with parts laying around
spal fans
aem wideband
grill (took it out for some stupid reason)
street unit rear mm
my entire car is down waiting for me to get my ems situated
Im supposed to have a PG Intake manifold, but its not here yet. Other than that I dont really have anything lying around that I plan on putting in the car. I do need to do some re-wiring of my subs/amps/etc.
i've got a couple things sitting around
dg motorsports fiberglass grill
mam thumper kit w/ gt30R
exedy stage 1 clutch
greddy profec b spec2 boost controller
440cc ford injectors
microtech lt-10s
J&S safeguard
C2 boost, oil pressure, water/oil temp
spec l/w flywheel
beavis block
MAM 94mm billet stroker crank
K1 H-beam rods 5.400 long rod with ARP2000 bolts
head fully ported/polished intake/exhaust ports, polished bowls, 5 angle valve job, Eibach valve springs, milled .0010, new valve seals, retainers and guides
custom cams, intake : 252deg @ 0.003" lift, 8.763mm lift in total, exhaust : 254deg @ 0.003" lift, 9.017mm lift in total
and the list is growing....
can't quite touch cct's list...
GT2871R
550cc's
Wilwood 13.1" BBK
Modified 3,4,5th Gears
Quaife LSD
Ported 626 Intake Manifold
AWR Radiator
Spal Fans
Samco Hoses
Thats about it for now... i've got other priorities that are keeping me away from getting the banana under the knife again. Maybe late summer.
