- San Antonio, Texas
- '15 CX-5 Miata AWD
Yea, howlin4u's write up is probably the best with that arrangement/tester cover. I don't see why you would run it out the door, seems like pinching the wire and it looks ghetto. I pierced the grommet, fished the wire thru (which btw is over the heat shield so most of it will be out of reach of water/dirt) and put some rubber seal spray over it. I then wrapped the wire itself in some of that split plastic tubing (oem style but ofc it's not "sealed" just a shield)). In hindsight, you could also lay the wire out and put a layer of plastidip over it. @ Skorpio is that a cotter pin hole sized lock on that bolt? I've been looking for something like that for my bike rack bolt; It's a threaded bolt, but the only hole on it is for the cotter (which I can't seem to find a cotter sized lock).
