So I noticed a little while ago that when revving the engine at a standstill the lights dim a little. I thought nothing of it at first, but now when my radio is where i usually listen to it my lights dim. So I decided to pull out the old trust Nexxtech (cuz I'm cheap like that) voltmeter. Here's what I found.
When idle voltage at the battery is roughly 13.9v.
Voltage when revving is in the 14's.
BUT, when idle and then revved a little (we'll say idle to 1500) the voltage takes a quick (probably less then a second) nose dive into the mid 12's.
From what I've been able to find online so far it sounds like I may have a diode problem in the alternator. So I figured I would check with you guys before I replaced it (or the car).
(and yes, I tested with the sub disconnected)
oh, and the belts are brand new as the alternator belt actually decided to give out on me... 2 hours away from home... at 9pm when nothing was open lol.
