Video RX-7 vs. F-350 Turbo Diesel
I bet that truck is running propane and nitrous or something that is fast for a heavy ass truck!
The truck is a Ford F350, but the Powerstroke engine was removed and replaced with a 12V Cummins. From what I understand it has a twin turbo setup, bigger injectors, and a fueling box. It wasn't running any drugs (aka Propane or NOS).
Here's the more detailed specs for people who are interested:
1995 F350 XLT 4X4 CC LB SRW Built E4OD by BTS with Baumannator controler. 12 valve Cummins with ported head, Piers race pump & Camshaft, 370 injectors, twin turbos@ 95psi boost 800 rwhp on #2 only 4.10's, Detroit locker, 36" PJ dirtgrips
wow 95 psi. I only want 16% of that amount of boost. ie 15psi for the mathematically challenged
It would be cool if you could import a euro spec turbo diesel from a protege and swap it into the MSP. Then you could have all the boost you want and get close to 50MPG.
Mazda100 said:
what's all that black smoke coming out the back??? Was it running rich??
It's unburned diesel. When you up the fuel pressure in increase the injector size in a diesel, you will have more black smoke.
yeah, the peterbuilt that I sometimes get to drive is a black smoke billowing MFer
Haha, most Peterbilt rigs have a Cummins Turbo Diesel under the hood just like my Dodge Ram and the truck in that video. :cool:
Honestly I have no idea what he spent. But it's not too expensive to mod a diesel. He probably spent somewhere between $7000-10000. Heres an example of what some of the stuff costs.....
Fueling Box ~$900
Injectors ~$1100
Twin Turbo Setup ~$3500
Fuel Pusher Pump ~$400
Exhaust System ~$500-700
Intake ~$250
The fueling box alone is the most cost effective mod. I can get a fueling box that adds 150HP to the wheels and 500lb ft torque to the wheels.
I would hope that with a near 6 liter engine they could do well. They should. Give me a 6 liter rotary and see what I pull.
They also weigh between 7500 and 9000 lbs. :D
that was a n/a rx7 not really a fair race =), but none the less, a fast freakin truck..he isnt lifted on bigger tires is he? if so he could get better times
