flat_black
Less manifold = More volume = More air required to keep velocity, since you have to fill that volume to keep velocity high. =) Removing the VTCS butterflies themselves will increase the overall volume, but the flow will be weird.
VICS/VTCS flaps open, the air gets pushed into the plenum by means of air refracting off the butterfly, like so:
VTCS open/VICS closed, the air flows straight across the plate of the butterfly:
So, removing the butterflies, you're not diverting air, and if the air is coming in at a huge boost pressure, it's going to fill the plenum, yes, but it'll all be turbulant air. If the air velocity it high enough, it'll just whisk past the opening like blowing across the top of a bottle.
Physics. =)
Oh, for completion, here's a shot of VTCS in action causing tumble:
Physics. =)
