Vibrations in 2019 CX-5
Recently picked up a 2019 Grand Touring CX-5. Noticed slight vibration on pedal initially, after several months increasing, accelerating around 40mph and at 1500/1600 rpm only. As soon as increasing or decreasing rpm the car is fine.
Any ideas? Thanks!
Sounds like wheel imbalance. Get your tires re-balanced and/or check for abnormal wear.
Vibration happens(or at its worst) at certain speed.. points to tire balance issue.
Flat spot can do that also if you park your vehicle for a while and drive it initially after.
That is why cars are transported on cargo ship with tires inflated up to 40 PSI or more.
