Vibrations in 2019 CX-5
Recently picked up a 2019 Grand Touring CX-5. Noticed slight vibration on pedal initially, after several months increasing, accelerating around 40mph and at 1500/1600 rpm only. As soon as increasing or decreasing rpm the car is fine.
Any ideas? Thanks!
Sounds like wheel imbalance. Get your tires re-balanced and/or check for abnormal wear.
Vibration happens(or at its worst) at certain speed.. points to tire balance issue.
Flat spot can do that also if you park your vehicle for a while and drive it initially after.
That is why cars are transported on cargo ship with tires inflated up to 40 PSI or more.
Any ideas? Thanks!
Did you ever find a resolution? I’m having the same exact issue and it’s driving me bonkers!
