Vacuum leaks!
Dvdap
Mazdaspeed Protege 2003.5
I am suffering from constant vacuum leaks and pinched hoses, causing thrown cels.
So I bought a vacuum block and new hoses to try and clean everything up.
The question I have is should I run the block through the brake boost line, before the one way valve.
Or should I tee it in to the brake booster
Or should I run a single line from a bigger port on the intake
Psi have 626 intake
Thank you
