Vac lines
flipmode815
mazda, mp3, #908
So I just went from a 626 intake mani back to a stock mp3 mani and now it has a messed up idle, It seems to be getting to much air. Can anyone take pics of the vac lines on the manifold so i can see if i have the lines hooked up right?
Do you have any loose vacuum lines that aren't connected to anything? As long as everything is plugged in, where the line gets its vacuum source from shouldn't be much of an issue.
The problem is that i dont remember what hoses went were, the 626 mani had different hookups from what the mp3 mani has.
Ok so now it seems it is idling ok other then about every 20seconds it takes a breath of air and revs up, what could be causing this to happen?
