- '08 Jetta; '10 Wrangler Unlimited
flat_black said:What's the prize? =)
the pride of getting it done and the fact you will have a V6 in yout protege!
Lord_Zath said:Perhaps the added weight to the front would be a good thing? Easier to get the rear end to swing?
chaosProtege said:just make it a mid engined car. take out the back seats and put the engine there. 50-50 weight dist. or put a wankle in it! lol
Protege52003 said:like when ford took the fiesta and dumped the 3.0 SHO yamaha engine where the rear seats were; the Shogun!
Autox MSP said:It is a very possible easy swap.
Pro5Monkey said:You got it tough guy!!! Check it out...
http://www.fordfestiva.com/gallery/grassroots_festiva_shogun.htm
If this ass-clown got a SHO motor in one himself, then there shouldn't be a problem getting a "K" motor in ours, and making it work!$!$!$!$!$$! (rockon)
Not yet. There are a few V6 Escorts though...anarchistchiken said:I guess that would explain why there are so many v-6 protege's running around....
Pro5Monkey said:Not yet. There are a few V6 Escorts though...
http://www.cardomain.com/ride/364076/2
Anything will work if you throw enough $$$ at it
flat_black said:Actually, the four cylinder FS-DE is non-interference. If you push out the valves even as far as you can to bind them up, they won't contact the pistons. The only way I can see the two colliding is with a) rod stretch or b) blowing a rod. Detonation seems to like to take it's toll on the valves, though, too, as more than one or three bent valves have resulted from premature detonation.
