tekkie said:you have to change the settings on the avcr for the car type and the number of cylinders, sorry I dont remember off the top of my head exactly what they are though![]()
|3utters said:Tried that already but I'll try again is someone can get the actuall numbers.
Chojin said:|3utters-
For the AVC-R to read RPM, you need to tap one of the ignition coil wires (Pin 26 - Red or Pin 52 - White). In the Car Select menu (under etc.), set Cyl to 2, set Spd to 4, and set Thr to the upper right.
-Shawn
