OK, I'm gonna start using this thread as a "here are things I did to my RX-8", similar to altspace and Reitrof.
So here's what we got for upgrades...
Bad (kinda) news first:
New engine!
Almost 70K on the clock. Engine diagnosed with low compression at 68K. The power felt down since 60-ish K or so (at least since the winter was over, the gas mileage seemed to have dropped over the winter). Compression numbers were about 7.0 6.8 6.7, 7.2 7.0 5.8 (!) @ 720rpm. After the dealer ran the intake vacuum test required by Mazda, Mazda granted a replacement engine the same day. I'm waiting to put it in until early July, since I'll be out of the country.
The current effects are that the engine runs, but the idle is rough (partially due to worn engine mounts, again) and low-end power feels considerably down. Not that the rotary has gobs of low-end below 5K anyways, but in comparison to Zelse's and Greenblurr93's cars, yeah, it's down on power. The top end seems OK, but it's probably not doing all that healthy either.
Cat is OK.
I don't know why the engine lost compression. I performed regular maintenance. Did redline it once a day. My theory is that I put a ton of highway miles on the engine, ~25K of them before the emissions recall to add more oil at cruising RPMs was done. That may have done some engine damage, though the engine did check out OK at the time. In March of this year, Mazda came out w/ another reflash that added even more oil. I put plenty of cruising miles during that time, so I wonder whether Mazda didn't fix the problem entirely the first time.
I did have my compression checked at 55K and it was at spec (mostly 8.x readings at 215rpm). So somehow, I began losing compression within 10K since then. According to a Mazda tech, Mazda requires the intake vacuum test because it can diagnose a blown/bad engine even when the compression is good. Perhaps that was my case.
Actually, I'm pumped for the new motor, because I'll get my power back! (plus some fuel economy)
The engine is getting replaced under Mazda's 100K/8yr engine warranty that applies to all RX-8s as of May 2008.
So, mod #1:
