VICS isn't what you lose from swapping ECU's; VICS is included with the MP3's, and all Protege's. What you're losing is VTCS, or Variable Tumble Control System. This causes the intake air charge to tumble when it enters the ignition chamber, which allows the car to warm up the precat faster, and doesn't add or remove any horsepower. You may lose some from the butterflies being there in general, but I doubt you'll notice it terribly much. That being said, I don't beleive you need to zip tie it open; I think it stays in that state under zero vacuum, which is what it'll be seeing, as the solenoid won't ever receive a signal. The ABS, I can't say; I'll find out shortly, and let you know, though. Presumably the speedo should work just fine, though, either way, as the speed sensor is right off of the tranny, and the ABS sensors are at the wheels.
