My cats are fail all the time.
If you like the pops and other sounds, enjoy the hybrid.
I'm sure you're aware that although this may not hurt your engine, it is highly likely that performance is degraded. MAF readings are off, so performance will not be as good as recirc.
the only time the maf reading is off by running vta or 50 - 50 is when you blow off and the car runs rich for a split second then its back to normal.
And after that "split second" and while the ECU is correcting, what does the engine do with that overly rich fuel? What does that shot of super rich fuel do to engine performance, even though the MAF and ECU are adjusting a "split second" later?
Ever look at the spark plug electrodes on a turbo car running VTA with MAF? That might cause you to think again. Spark plugs are the silent witness as to what is happening in the combustion chamber. Just a thought.
Again, I'm not sure this is true. The way I understand it, air is being released through the BPV anytime the car is in vacuum (any time it is out of boost). I may be wrong, but I always thought that the boost "closed" the BPV allowing boost to build, then once you let off the gas the vacuum allows the BPV to "open" again...but that it would also STAY OPEN until you were in the boost again. If this were the case the MAF reading would be off 90% of the time instead of just a few split seconds.
Just my thoughts on it.
I'm changing my plugs to iridium, colder plugs when my TMIC gets here, so we can have a look then too.
