Well I don't have a afr gauge to monitor it. But would I know a difference in ride quality?
Actually as long as you maintain proper AFR, trims aren't that big of a deal, but when your ECU is correcting by a factor of 24%, and 25 to 30% is the upper limit, it gets a bit scary.
At cruise your car will try to keep it around 14.7:1. You'll usually see it bounce around in the 14.3 - 14.9 range while cruising. When you really go WOT you'll see the number decrease into the 12:1 and sometimes even as low as 10:1 after a few seconds of high boost.
Fuel trims are technically safe once the ECU has learned the characteristics of your engine with its mods and they stabilize. The car can only adjust around +/-25% though, so when I see my trims at +24%, I get concerned.
I think most people would agree that -5% to +5% is a pretty good number for LTFTs.
Now, I know that it's not good for our cars to run vta, but with the hybrid you can run 50/50. So will it still be harmful to drive it on 50/50 as apposed to full recirc. Sound doesn't bother me much, I don't care to be the loudest or loud, but I don't really like the sound of the turbosmart in full recirc, on 50/50 on the other hand it sounds great!
