iON's FMIC price is also based on fabrication time. their cores aren't generic units, they order different cores because jack wanted the core to be as big as possible without interfering with any of the body/frame along with the pipes. hiboost FMIC also has custom endtanks and piping.
and heatsoaking is a problem, because once the intercooler can't cool down the air, engine operating temps go up. engine operating temp is always going to go up regardless of what IC is used. if a good amount of air that can be correctly simulated to flow across the front of the car can be used, then results would be consistent.
