Turbo/Boost Issues?
Bakum said:
Get used to it my friend, this is only the beginning. If you knew nothing about cars before you will quickly learn on your MSP
o know, im very common with evo's........
and a ls/vtec turbo eg
MSP's are a new boat for me... I see its going to need a lot of work...lol
alright, so the dealership called me back and said they cannot find anything wrong, but there is, how do i convince them to get me a new turbo?
One thing the dealership likes to do is NOT take the car for a good test drive. They will let it sit, and drive it around the block while its cold and find nothing wrong, on top of that, when it's a turbo issue, they don't get on it enough to test it. Somebody else had a similar problem and they ended up taking one of the writers for a ride to prove it. I forget where the post was, i'll search around and see if I can find the post about it.
Mine is making the same noise. Seems to be only when it's hot. Is the consensus that this is the turbo itself or just the wga? Should i see if i could get warranty to cover it? Or is that just an uphill battle? thanks
My boost wouldn't go pass 4 psi either. How do I inspect for boost leak? Do I just look at the pipes by eyes? And what should I told the dealer to fix it?
Sorry for many noobs questions.
