Mazdaprotejawn
- 2003 mazdaspeed protege
Anyone know of a write up? Just wondering
Here's what I followed when I took on the task of changing my open diff to mfactory. Changed out my 3rd and 5th gears also when I was in there.
http://www.mazdas247.com/forum/show...-Teardown-amp-Rebuild-w-LSD-amp-5th-Gear-Swap
Ok, could u shift through the gears no problem, but it woudnt move or act different then normal? Cause then that would be the exact same thing thats happening here, is there a way to change/look at the lsd without pulling trans?
Yeah it goes through the gears fine, in reverse it feels like it barely wants to catch, im curtain its the diff, id have the trans out by now to confirm, but ive been working 7 days a week 60-70hrs a week, = no time to start ripping into it
Id say its the lsd also. Thats exactly how mine was acting.
Awesome the more i hear it the happier i am to know its not the trans
The lsd isnt cheap though. I replaced mine with one from street unit, its an welded one for reinforcement.
Keep in mind with the MFactory you have to drill the rivets off the ring gear on the stock diff and bolt the final drive/ring gear to the MFactory diff. It should come with ARP bolts.
