speedcicle
- 2003 mazdaspeed protege. Spicy orange mica
Just wanted to share a bit of info with you if you don't already know. I have used a few different kinds of trans fluid. Mobil 1, redline, stock 75 90w, just to name a few. Now i am running pennzoil synchromesh and let me tell you this is the best one out there. I used to grind a bit going into second..GONE!! Now every gear change is a smooth as silk. So if your not using it already i recommend the change highly. Also i added equi-torq lsd additive. Just my opinion but if you are having hard gear changes give this stuff a try.....
