Model : CX-5 Sport AWD
Year : 2016 (bought new in Aug 2015)
Current Miles: 15,900
VIN : JM3KE4BY4G067****
Well guys and gals just letting you know my transmission is trashed and getting replaced under warranty. My transmison had a 4-5 second delay from when I changed the gear selector to Drive before it will start moving forward. Even when I'm driving and come to a complete stop, after I release the brake pedal It has the same delay before it will move forward . If I attempt to give it some throttle before the 4-5 seconds delay, the motor will rev as if I where in neutral , then it will jerk forward hard when it engages . Similar to doing a neutral rev and drop to "D" on an Auto trans car.
I took it in to the dealer and they said they seen it happen before and I'll be getting a new transmission . I'm not sure if anyone here has had this issue but I thought I would share this info in case you run into a similar issue. My transmission went out with only 15,900 miles so I guess this issue can arrise at lower a mileage .
